Ok, i accidentally stumbled upon this unique bike as my friend wanted to get rid of it. The person in her apartment before won it and never used it, and she didnt want to to gave it me… For about £15. I now see these are worth quite a bit.
Ive tried tweaking it a bit (an tightening the many loose bolts) but stumbled into some issues.
First, the tension adjuster. Ive loosened it and i assume you are suppose to be able to move the bolt in the direction of the rear of the bike but it wont budge.
Second, i tightened the rear wheel and this has pushed the disc closer to the brake. I also tightened the brake at each side. This caused it to touch one side of the brakes. I attempted to remove one of the washers on the rear disc brake caliper but now have found there is like a screw within a screw and im finding hard to screw this all back together…
Any tips? Links for good maintenance??
Also, how do i tell what model my Strida is for sure? Ive looked at pictures and it looks like a 5.0.
