Hi, an oldie but newbie to the forum. Could somebody tell me if there is an easy way to remove the hand grips (2018 LT) without damaging them. YouTube couldn’t help me. Any ideas/advice welcomed. Thanks.
Hi Monsai san,
How about inserting a bamboo skewer (I’m not sure if they have them in your area) into the grip to create a gap, then spraying some parts cleaner into it and shaking it while pulling it out?
Hello Monsai,
welcome at Stridaforum ![]()
Sure; the best way to get rid of grips is pressurized air - air compressor! Insert the nozzle between rubber and bar - the grips will start to “hover” on the air cushion ![]()
You can also try pure alcohol, take a syringe and squeeze it between grips and bar.
Good luck,
Greatly appreciated Doranine and Chris. Skewers are easy to come by (Japan), sadly don’t have a compressor though. I will also try the syringe and alcohol (no pun intended). Thanks again.
