Rear wheel :-\
I usually pump both tires to maximum (6.5 psi), but front wheel is ok. Just bad luck, i guess.
At least now I don’t have to bother with broken spoke replacement on this wheel =))
Rear wheel :-\
WTF? ![]()
What are you doing with your Strida - downhill race? ![]()
http://www.orschlurch.net/2012/06/02/downhill-ueberholmanoever/
Does it happen during this overtaking maneuver?
Cool video =)
As with torn hub, I’ve found this accidentally, while inspecting tire pressure. It is rideable, I was able to commute home. Usage was normal (except for one missing spoke on that wheel), with usual potholes.
if you are going for replacement 16 inch rims get the LT ones so you don’t have to worry about spokes anymore ![]()
