My wife is looking to buy a folder and very interested in Strida 5.
The Strida 5 manual stated minimum height is 145cm.
What about the minimum inside leg length requirement?
Also, what is the lowest saddle height (from the ground) that can be adjusted?
Here is link to my post on BF if my text is bad worded do tell me and I try go there and edit but maybe they have time limit for editing. Don’t remember.
Trueno at bikeforums dot net has given you the specs on the smaller Strida Mini
9.8 lbs (9 kg)
7000 Series Powder-Coated Rustproof Aluminum
Kevlar Greaseless Belt Drive (up to 50,000 miles)
Alloy 14” Rustproof (36 cm)
Cable Disc Brakes
Single Speed
40” x 20” x 9” (102cm x 51cm x 23cm)
Gel
Welded
Holds 30 lbs (14 kg)
175 lbs (80 kg)
4’4” – 5’4” (140cm – 160cm)
The NORMAL strida 5.0 specs are as follows:
SPECIFICATIONS: Standard
22 lbs (10 kg)
Alloy 16” Rustproof (41 cm)
Cable Disc Brakes
Single Speed (56 Gear Inches)
45” x 20” x 9” (114cm x 51cm x 23cm)
Gel
Welded
250 lbs (110 kg)
5’4” – 6’4” (163cm – 193cm)
