# Schlumpf Speed Drives on Ebay
**URL:** <https://www.stridaforum.com/t/schlumpf-speed-drives-on-ebay/1179>\
**Category:** General Strida Chat\
**Created:** [June 10, 2016, 10:15pm UTC](https://www.stridaforum.com/t/schlumpf-speed-drives-on-ebay/1179 "2016-06-10T22:15:05Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![DoctorStrida](https://www.stridaforum.com/letter_avatar_proxy/v4/letter/d/a4c791/32.png) [@DoctorStrida](https://www.stridaforum.com/u/DoctorStrida)\
**Post date:** [June 10, 2016, 10:15pm UTC](https://www.stridaforum.com/t/schlumpf-speed-drives-on-ebay/1179/1 "2016-06-10T22:15:05Z")
</div>
Was about to buy an EVO, would love a C1 but it has no gearing & for a hard rider, I need gears.
Own a couple of SX’s, true racing Stridas but for the gears.
Reluctant to invest $1300 for an EVO, then $200 in pedal upgrades, etc.
Was searching on craigslist for used stridas and found a link for ebay stidas and then speed drives/gearing.
Which one would you guys recommend, they are Taiwanese but say they are the same German engineering?
Do I need to replace more than just the $280 components?
Is it complicated, could a bike store do it or do they need specialized tools & parts?
Here they are, all 3 seem slightly different;
This one is for $280
[ebay.com/itm/Schlumpf-Speed- … SwCQNWf4v7](http://www.ebay.com/itm/Schlumpf-Speed-Drive-Crankset-Strida-Upgrade-Kit-Heel-kick-shift-2-speed-ATS-/191702265594?hash=item2ca2586efa:g:dHIAAOSwCQNWf4v7)
This is for $400 but seems to have a whole lot more
[ebay.com/itm/Schlumpf-Speed- … SwmrlUugHw](http://www.ebay.com/itm/Schlumpf-Speed-Drive-crankset-for-STRIDA-Two-speeds-170mm-Folding-bike-/301491338172?hash=item463248bbbc:g:WbgAAOSwmrlUugHw)
This one is for $480 but it talks about an ebike application
[ebay.com/itm/Schlumpf-Speed- … 1491338172](http://www.ebay.com/itm/Schlumpf-Speed-Drive-Extended-Bottom-Bracket-100mm-E-Bike-Electric-BIKE-ATS/191856644445?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D777000%26algo%3DABA.MBE%26ao%3D1%26asc%3D37183%26meid%3D15b373bae4d14a3781bf15d36df18a6c%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D301491338172)
Has anyone had any recent experience with these companies?
Does it make that much of a difference, having a second gear?
What are the real advantages?
**Post date:** [June 10, 2016, 11:24pm UTC](https://www.stridaforum.com/t/schlumpf-speed-drives-on-ebay/1179/2 "2016-06-10T23:24:01Z")
</div>
> [@Doctor Strida](#):
- Correct would be Suisse engineering, btw…
> [@BSA](#):
> “… as an enthusiastic owner of a Strida 5.2 I would be highly interested in where to get a speed drive and in knowing the costs of the precious piece. Sharp, possibly not really competent, tongues here in Austria claim the Strida MAS (=ATS drive) does not operate properly.”
> [@Mr. Florian Schlumpf](#):
> “The sharp tongues are not totally wrong: years ago we made a licence agreement with a Taiwanese company.
> Presently, these gear drives are mounted into the Stridas - unfortunately with little success since the quality leaves a lot to be desired. For this reason we decided to produce a tailor-made alternative including the excentric fitting for the Strida, which is now available and works faultlessly. However, with “made in Switzerland” and 5 years full warranty this part is also a little more expensive.”
From here:
[Re: Has anyone retrofitted a schlumpf on their strida?](https://www.stridaforum.com/t/photos-of-stridas-in-hong-kong/23/1)
If you mean your first two links:
They seem to be complete, but without tools.
The third link is a longer version which is not suitable for Strida (no beltwheel, no belt, no eccentric bottom bracket).
> Is it complicated…
I’ve done a lot of work just to help Strida riders to judge about this delicate and personal question.
[Re: Has anyone retrofitted a schlumpf on their strida?](http://www.stridaforum.com/forum/viewtopic.php?f=2&t=2751&&start=45#p7258)
Nobody else than YOU can tell if it will be complicated for YOU.
> …could a bike store do it or do they need specialized tools & parts?
An experienced shop must be able to do; they will already own most of the required tools.
Just a short, not productive mail contact with bikegang.
My opinion telegram style:
One gear - much too less.
Two gears, heel gear shift - cool, but still too less.
Three gears, backwards pedaling gear shift - not my style, well, Ok…
Seven gears - now we’re talking 🙂
Shifting by heel kick during pedaling forwards. 🕶
**Post date:** [June 12, 2016, 1:33am UTC](https://www.stridaforum.com/t/schlumpf-speed-drives-on-ebay/1179/3 "2016-06-12T01:33:28Z")
</div>
As always, a fantastic answer from Blackstridaaustria!
While I can do almost anything, it seems;
At $400 for a Taiwanese kit
Without buying the specialised tools
Then the Labour costs
It’s much cheaper to buy an EVO.
Moreover after reading what the inventor suggests, deep in those threads, about $650 plus, it makes even less sense.
THANK YOU!
