# Questions and ideas
**URL:** <https://www.stridaforum.com/t/questions-and-ideas/1381>\
**Category:** Strida Problems and Answers\
**Created:** [November 3, 2022, 4:41pm UTC](https://www.stridaforum.com/t/questions-and-ideas/1381 "2022-11-03T16:41:01Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![JoeySeeker](https://www.stridaforum.com/letter_avatar_proxy/v4/letter/j/a88e57/32.png) [@JoeySeeker](https://www.stridaforum.com/u/JoeySeeker)\
**Post date:** [November 3, 2022, 4:41pm UTC](https://www.stridaforum.com/t/questions-and-ideas/1381/1 "2022-11-03T16:41:01Z")
</div>
Hi everyone,
Can you tell me exactly the diameter of the hole for the bottom bracket in the lower tube of the Strida LT?
I also have another question or idea:
Do you think it would be possible to use the eccentric adapter BB of the ATS speed drive to mount a standard bottom bracket, for example Shimano?
I don’t know what the diameter of the adapter hole is, if anyone has it, tell us and I think something could be done.
[bikegang.ecwid.com/ATS-Eccentri … p142654160](https://bikegang.ecwid.com/ATS-Eccentric-Bottom-Bracket-adapter-for-Strida-p142654160)
Last question. My LT has a plastic/alloy BB, and I see there is an alloy BB, but some webs like strida.nl says plastic is for LT and alloy for 5.x. Can I use alloy BB for my LT? Do you think it is better?
Thank you
**Post date:** [November 3, 2022, 5:03pm UTC](https://www.stridaforum.com/t/questions-and-ideas/1381/2 "2022-11-03T17:03:58Z")
</div>
> [@JoeySeeker](#):
Will be around 51,5 mm because the exzenter (BB)'s diameter is 51,3 mm at the flanges.
> [@JoeySeeker](#):
If that would be possible (I don’t know) then you’d still have the problem of missing width - the Strida BB’s are just around 58 mm wide, I guess (?)
> [@JoeySeeker](#):
Sure, you can use the alloy BB.
Yes, I do think so; never heard of a broken alloy BB, but plastic ones did break (occasionally).
There are just two items which separate a LT from an SX - these are the wheels and the excenter.
To avoid misunderstandings; the ATS excenter of your link from bikegang - this is a dual speed excenter and it fits only the ATS (or Schlumpf) speed drive.
Dual speed and single speed excenters are a bit different!
