Here is a photo of the bottom bracket of the 3-speed Strida taken at the Taipei Cycle Show 2011
NOW we are talking
but after trying a 2 speed I still like the simplicity of single speed
The bottom bracket looks huge so it doesnât look like a direct retrofit. BUT we can probably buy a new bottom tube and that as a set, now weâll just have to wait to see if ming would offer it. They did say before they would not be offering the LT wheels separately and we where able to buy them afterwards. I can only hope since this would actually stop me from spending on the schlumpf if itâs the same price for one more gear.
It is a kick-back shift bottom bracket which has 3 gears that you have to back pedal 60° in order to shift between gears.
The gear-shifting pattern is like this: 1â2â3â1â2â3âŚ
The problem with 2 speeds is that one is too low and the other too high, so you end up missing the original gearing (in the middle).
Judging from the fact it took ages for Strida come with SpeedDrive, it will take years to get it released to market, or it will never be releasedâŚ
But it is indeed interesting to learn the âkick-back shiftâ ďź
Seems like strida updates are moving like bromptons, Small changes of refinement as time goes on instead of drastic changes that dahonâs go through. But with that as a benefit you know you will be able to find spare parts for many years because of this. While some folding bike manufacturers you are out of luck after 1-2 years max.
A rumor coming out from Taipei stated that the BB would go under a year-long testing, therefore the bike might be released in 2012.
Given that Sturmey Archer moved to Taiwan, do you think the internals are Sturmey design? It wouldnât make sense for Ming to try and design an epicyclic gear from scratch. Plus Sturmey came out with an innovative 2 speed kickback hub last year, now in full production.
Also Amuro, for us April latecomers, your âbandwidth with Photobucket is exceededâ, so we canât see that interesting photograph. Do you have any others?
cheers,
Minkair.
Hi Minkair,
The bandwidth limit of my photobucket account resets on 21st of each month, so you can see the embedded picture again later.
If you canât wait, you can just simply copy the follwing hyperlink and open it by your browser manually.
Cheers ,
Amuro
When I visited strida.com, I saw following information :
STRiDA 3 speeds is coming soon! What is the best new name for it?
STRiDA EVO
STRiDA S3 ( Sport Trio )
STRiDA 3S
Note: if you vote once or if you visit several times you might not see above info again.
If that is the case, you might need another browser.
Awesome news! But whatâs up with this new product name capitalization: STRiDA?
Maybe it will be called Strio or S3da
Or�
The latest photo!
http://www.strida.com.tw/tw/news/?method=detail&aid=130
http://www.facebook.com/photo.php?fbid=10150511138172661&set=a.10150111123337661.290786.290433152660
More than 10.000 votes!
In the 2nd questionaire for your favorite colorâŚ, I have noticed that it is named as âSTRiDA EVOâ.
I am wondering if this is just because the name got most votes in the 1st questionnaire or beause Ming Cycle made up their mind or bothâŚ
All those EVO and 3S and 3D sound too geekly/smartphonish to me⌠I guess Strida deserves something more zen-like On a bit more serious note, I like the simplicity of the singlespeed Strida. My 18" SX climbs uphill pretty well and on plains, where Iâd pull a higher gear if I had one, it just promotes maintaining a higher cadence, about 90-100 rpm, which is a good thing anyway â why would I need all these overcomplicated/overpriced multispeeds? Who else thought about fixed gear conversion??
