When my Strida LT is folded, if I need to pull it towards me in some situations like avoiding pedestrian, the left crank arm would rotate backwards then hit onto the side of my rack then get stuck. When this happens, I need to lift my bike up, rotate the crank arm forward.
In other words, I can only push my folded Strida forward since the crank arms won’t rotate while you push forward.
Anyone had the same problem?
Is there any thing I can do about my problem?
the mentioned movement of the cranks is a normal feature of the freewheel,
there’s no way to “switch off” this characteristic.
You should only push, but not pull “her”
Thank you for the advice. I never know Strida can be folded in a slightly different way. Hmm…maybe I should buy that clip and see if it solves my problem. For now, I shall avoid pulling my Strida in backward motion.
