No, there’s at least 5 mm room between both tubes.
Hmmm, I believe the issue can be found a bit lower…
Could you please check if the plastic washers (part nr. 376) are at their place below the magnet counterpart?
Caution: While remounting the bolt (nr. 379), do not use much force - otherwise the part nr. 338 will be bent!
Below the parts sequence of the rear wheel:
You might also solve the issue by adding a second washer below the magnet at the front wheel:
(Ignore the red arrows, they apply to another post.)
Please note: Using a thread locking compound is a must for both wheel bolts!
I’ve written the text above a bit misleading, sorry.
(Previous post already edited.)
Actually was meant to use the washers at the front wheel (magnet location), not at the rear wheel (counterpart of the magnet with small hex screw).
Anyway - it worked and seems to be OK
Many thanks for the compliment about the Stridaforum!
Don’t worry for the “guest”, after a while of logged-in browsing you will be automatically logged out…
And to change the poster are just a few clicks needed
