Strida evo 3 VS Strida SD
The place to report and discuss your experiences of owning and riding the Strida. Perhaps your first impressions, or your story of a big trip.
Postby Driwuoks on Mon Oct 21, 2013 2:41 am
Hello
What are the differences between the strida Evo 3 and the SD? (Besides 3 speeds)?
What is the maximum speed of evo strida March 18 "? :|
Thank you very much! :roll:
Driwuoks
Re: Strida evo 3 VS Strida SD
Postby Blackstridaaustria on Mon Oct 21, 2013 6:13 pm
Hello Driwuoks,
besides the higher weight (maybe ~ 1,5 kg) of the EVO gear drive and the bottom tube (+bottom bracket of bigger diameter) there is no difference.
The 3-speed Strida
Gear ratios information about different models of Strida
Once again, as already mentioned here Strida EVO3 with 18" wheels?,
the question for a maximum speed cannot be answered generally - in principle, I'd say NO Strida will be faster than 0 km/h...without rider...
And I claim hereby also that all my Stridas can be faster than 150 km/h...if I throw them out of an aeroplane window...
YOU are responsible to make a Strida fast, you need to pedal as fast as possible...what's your usual cadence?
How long can you keep that cadence?
Are you a sportsman?
STV@gmx.org
StridaTuningVienna
Postby Driwuoks on Sat Nov 02, 2013 7:02 pm
Currently I have a Strida MAS, which I consider quite fast. Anyway I think that buy you a evo 18". Thank you for answering :)
Driwuoks
Postby Blackstridaaustria on Sun Nov 03, 2013 10:37 am
You're welcome :D
if you are fast on a MAS you will be anyway faster with 18 inch wheels, I mean...
Hopefully you noticed the big difference in the gear shifting procedure;
change gears on SD means sideways kicks with the heels
- possible even while pedaling forwards - as you will know :lol:
on an EVO you have to pedal backwards for 120 degrees per gear.
STV@gmx.org
StridaTuningVienna
Postby Chester_Tan on Mon Dec 23, 2013 3:08 am
I have an SD with 18" wheels and I think based on the numbers it's faster than the EVO with 18" wheels.
Chester_Tan
Postby Driwuoks on Mon Dec 23, 2013 3:23 am
Good to know. In one more week, purchasing tires 18 "for SD =)
Driwuoks
Postby Blackstridaaustria on Mon Dec 23, 2013 9:46 am
Chester_Tan wrote:I have an SD with 18" wheels and I think based on the numbers it's faster than the EVO with 18" wheels.
Dear Chester, which numbers do you mean?
STV@gmx.org
StridaTuningVienna
Postby Chester_Tan on Tue Jan 14, 2014 11:07 am
Hi BSA,
I mean the gear inches of the SD with 18" wheels
Low gear (direct drive)
(80 t / 30 t) x 18"
= 2.67 x 18"
= 48 gear inches
High gear (speed drive)
((80 t * 1.65) / 30 t) x 18"
= (132 t / 30 t) x 18"
= 4.4 x 18"
= 79.2 gear inches
Chester_Tan
Postby Blackstridaaustria on Wed Jan 15, 2014 11:02 am
Hi Chester,
yes, thanks to you I'd a closer look and do know better now.
I thought actually that the gear ratios of high/low SD gear would be 100 % equal to the high/low gear of the EVO.
That's wrong! :oops:
Hopefully you'll also accept my apology, I've corrected that already here:
Re: Gear ratios information about different models of Strida
STV@gmx.org
StridaTuningVienna
Postby Chester_Tan on Thu Jan 16, 2014 3:26 am
Hi BSA,
No need for an apology. :D
Chester_Tan
Return to Riders Reports
Users browsing this forum: No registered users and 1 guest
